Question: Is it possible to play vcd on a dvd (stand alone) player?
DeViSoR
277
I'm thinking of buying a dvd player (not for my computer), and I wonder if there is anyway to play vcd on a dvd player? If yes how, do I have to change anything on the vcd folder structure or?
Henry Kuo
2,248
at least from all the DVD players I have seen, they are compatible with vcd 2.0, so you should be able to play vcd there without any modification. the machine will know what to read.
I am sure there will be some exception, but again, most machines i have seen have that ability. look for vcd 2.0 compatibility.
DeViSoR
277
K this model that I have got a good offer for is 1 year old.. cost like 1500NOK, ordinary price today for that model is 3500NOK. It is a panasonic but I dont remember the model :/ .
Thanks for the info....
Eug
24,165
1,809
Price doesn't help to know if it plays VCD, because many of the cheap ones do and many of the expensive ones don't. Look on the Panasonic website, but I think most of the Panasonics play VCD.
Edit.
If i'ts VCD on CD-R, most of the DVD players DON'T support it (but many do). However, many seem to work with some CD-RW discs.
DeViSoR
277
He he.. I was just pointing out that I was going to buy this one anyway..
Well that sounds strange Eug but you might be correct, lets hope I'm lucky.. I'll get the player at work tomorrow so I'll have to chance to check it out. If it is just a bad player well then no no.
/me kind of tired of having a 20m long s-vhs cable from comp to TV..
BA
5,004
most do.
I actually saw a a VCD player at AllElectronics for $50.
Heretik
931
My Sony will play VCD's....even ones I burn myself but only if I write them to CD-RW....won't read CD-Rs...
LocutusX
My Panasonic DVD-A120 plays VCDs just fine. As long as they are burned onto CD-ROM (factory-made) or CD-RW. I haven't yet found any CD-R's that will work. Probably won't.
DeViSoR
277
Ok.. this is my question then.. It was a panasonic DVD-a150 and it can handle vcd :cool:
But as you guys say.. cd -r is not liked by the dvd player... I have 4.. cd-rw cds.. that are used. Is there anyway to "format" it so I can copy cd to cd or do I just have to buy new cdrw every time I want to look at a vcd I want to watch..
LocutusX
I'm not sure what you mean, but CD-RWs are reusable. If you have a collection of 10 VCDs on your computer but only 2 CD-RWs, you could theoretically watch each of them in order, buy burning one at a time (or 2 rather, since 1 VCD movie usually takes up 2 CD's) and then use your burner's format utility to erase it (I think Nero has one built-in as well... it's just a function on the burner, every burner should have it).
DeViSoR
277
A other question (might be stupid but what tha heck).
I see that most vcd I have they are in dat format and not mpeg. My dvd player do future vcd playing. But is this just for mpeg or do it also support dat?
DeViSoR
277
K.. I have tryed to burn (copy) vcd from cd-r to cd-rw did not work. 8-(
any suggestions?
LarryJoe
2,425
It has to be in mpeg1 format for it to play on a DVD Player. You need to convert it using a plugin such as the Panasonic encoder plug in for Premeire. Go here and learn everything you will ever need to know:
VCD-Helper
LJ
DeViSoR
277
doh.. followed the guides there. and had no problem creating vcd.. but.. my dvd player do not want to read th vcd.. I have tryed it on cd-r and cd-rw (tdk)
Anyone have had success with this dvd players (panasonic dvd-a150) if yeay.. please let me know.. or if you have more suggestion.. please post :cool:
LocutusX
Try different brand CD-RWs... try using NERO to burn a MPEG-1 (.mpg) file to it... can't think of any more tips at the moment.
oldiex
78
I have an Apex DVD player and it plays VCDs that I have created myself. It also plays MP3 CDs.
DeViSoR
277
oldie is there any surtein folder structure you have on your mp3 cd or do you have all mp3 in the rot?
I had finaly succes with playing my vcd on the dvd player. It seems that the first cdrw from tdk I had was kind of rippy. When used a new one the dvd player took it perfectly.
thx for the help guys. Oh oldie I want a answer from you :cool:
Huma
1,301
The Apex 600 is the most amazing pirate toy in the world.
plays burned vcds, and even svcds (which are amazing).
LarryJoe
2,425
I have the Apex and keep all the MP3's at the root. Navigation on the Apex is not that great.
LJ
Oric
965
101
Samsung DVD Players wont play Green or Blue CD-R's although Silver Dyes are playable
oldiex
78
DeViSoR
I just burn the mp3 files in the root directory. Make sure that the titles are as short as you can make them. If the titles are too long the DVD player will not open the directory.
thorin
Alot of stand alone DVD players carry warnings not to use CDRs in them (as the DVD laser can essentially bleach the dye layer).
Of the 3 or 4 DVD plays amongst my family and friends all of them can read VCDs.
Thorin
