Question for VB 2005 guys...
Specialk92282
143
Yeah so I've worked for about 30 hours on a database program that interacts with excel and quickbooks only to find the switching to other computers gives me errors of System.InvalidOperation. I'm certain its not a code problem and I believe it only relates to the DLLs. This program work sfine on my computer but messes up on others. I have reason to believe it may have something to do with the GAC but I have no idea what it really does.
My referenced DLLs also mysteriously turn into Interop.DLLNAME instead of the original name. I've been programming with VB .net 2003 and VB6 for a while and this one is really puzzling...if you know a lot about deployment shoot me some ideas please, Thanks!
InfiniteLurker
235
Did you create an installer to get the application running on the other PC's?
Start digging around here and here
Sorry I don't have more time right now to get into specifics - but those links should get you on the right track...
WannaFly
2,811
It doesnt sound like a Deployment problem. If your program interacts with excel and quickbooks, changes are that excel and quickbooks need to be installed on each computer also - are they?
The referenced dll's renaming are fine, that is a wrapper that is created (I believe).
