Question for Unix guru's - diff command
calbear2000
1,027
Hi,
I have 2 gigantic files I'd like to diff. After diff runs for a few minutes, I get "diff: files too big, try -h"
I was thinking of dividing each file into 2 halves so that I can diff each half at a time. Is there a way to break up a file without manually going in with a text editor to cut and paste?
Thanks
calbear2000
1,027
Excellent... the split command. Thanks Bootprint
"Oh mighty unix, is there anything you can't do?"
manly
13,584
4,237
I'm surprised diff cares how long the files are. Another way of doing this would be to compute a hash of each file, and compare the hashes.
The command md5sum is common on many UNIX systems; MD5 is a de facto standard for computing cryptographic hashes (although it's somewhat being deprecated in favor of SHA).
Go Bears! ;)
ggavinmoss
4,798
Go Bears! ;)
Wouldn't this only help if he wanted to distinguish if the files were different and not HOW they were different?
-geoff
manly
13,584
4,237
-geoff
Yes, but most times people don't diff any text files larger than a few Kbytes in size for the actual deltas. Gargantuan files are typically binary of course.
Since he mentioned a text editor, I suppose it's (remotely) possible he's interested in the actual differences between two "gigantic" files.
