If they did, what happens if you want to switch back to cable service or land-line telephone service later? If not, what did they do during installation?
There was a big story about ATT doing this to a lot of people.
I can tell you that the cable companies will run new wire for you, but it may not be exactly the way you want it.
NOT posting as an employee or representative of any cable company.
Did they do anything with the coaxial cables in your house? Reason I'm asking is I wanted to see if I could get both cable Internet and U-Verse Internet concurrently.I've heard about Verizon ripping out existing wiring for a FIOS install, but never about ATT doing it.
Uverse does not replace any wiring at all. They pull off the old telephone box on the outside of the house, and replace it with a new box (reusing the incoming telephone line, and your house's telephone circuits), and then run a CAT5 from that box to the Uverse gateway inside the house. (I recently got Uverse installed, and I stood there and watched the guy do it)
If I wanted to get U-Verse television service later on, they would have to switch it though, right?If you tell them not to, they are not allowed to touch inside the house. If they are like any other installer I have worked with, they will just leave the outside coax disconnected. Technically they are like any other service provider, they are not legally allowed to mess with the other services.
OK, so AT&T installers will install a new box outside the house (NID) and disconnect and reconnect the copper(/fiber) wire from the CO to this new box. Then they will run a VDSL cable to the Residential Gateway (RG) device which will be the distribution point for the Internet, TV, and phone services. From the RG, the Internet is distributed via RJ-45 copper Ethernet, the telephone is distributed by RJ-11 copper (Cat-3?), and TV can be distributed via coaxial or copper Ethernet. Is that it?Depends on what you consider "have to." I believe uverse is nothing more than special box, attached via dsl that has a "TV out" designed to work with their boxes. I don't think the service requires the use coax at all as it can run purely on ethernet. The coax jack as I recall on the unit is for HPNA (coax network.) So you can let them pull cables but tell them not to touch existing. You can also instruct them to not touch the poke through.
PS Uverse has changed the gear like 4 times so it depends on what you get also.
Did they charge extra for running new coaxial runs?I asked the tech to reuse an existing coax cable to carry the signal fromt eh gateway back into my living room for the main DVR, so he did that. They won't cut/reuse/remove existing coax if you tell them not to, and they will leave existing connections live if you tell them to except the phone box, which is of course part of the Uverse install. You do need to be specific about what you want done when they tech shows up, don't just assume that they'll do it right.
