Question for RavenSEAL
Status
Not open for further replies.
OCGuy
27,224
37
I have figured out what ATOT's Xmas present is this year: Multiple threads full of fail.
Enjoy!
RavenSEAL
8,661
LOL, i just randomly found this thread after google searching my nickname :eek:
The answer is, I had an extra stick left over lol. So i thought i might as well use it, cost me $30 after all, can't hurt right?
I have 1x 2GB and 3x 1 GB as of right now. 2 of the 1GB modules are paired.
Ichinisan
28,298
1,235
Which is worthless unless you are benchmarking.
Almost anything that's CPU-limited should be affected by memory bandwidth...even between high-speed caches on the CPU die. When encoding video, for example, most of the CPU cycles are wasted; waiting for more data from the system memory. This will be true until the interface to system memory matches the core clock of your CPU (not happening with any architecture we can conceive at this time). If I understand correctly, dual-channel gives double bandwidth...which is very significant.
RavenSEAL
8,661
Hey, unless ya'll wanna send me a check for $30...I really don't think it matters, my games play just fine o_O
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Almost anything that's CPU-limited should be affected by memory bandwidth...even between high-speed caches on the CPU die. This will be true until the interface to system memory matches the core clock of your CPU.
Affected yes, noticeable in real world applications? Nope.
BoomerD
66,404
14,798
Just delete the thread. I didn't mean to make a fuss!
Damn...if you're gonna hang around here, you need to learn to stick up for yourself and tell the assholes to shut the fuck up...:p
MOST OF US here aren't too bad...once we get to know you...
BTW, howzabout some more pics? :biggrin:
olds
50,125
780
I'd hit it too.
guyver01
22,135
61
yanno what's funny?
Ricky happens to be ZaneJohnson's name too...
could this be ZJ's 'dual' account?
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
If I understand correctly, dual-channel gives double bandwidth...which is significant.
There are many sub systems with greater bandwidth than can be currently utilized. My favorite lately is SATA 3.0 which is marketed as a must have and adds exactly zero performance gains over SATA 1.5
Ichinisan
28,298
1,235
I had edited that post.
Video encoding is sometimes a real-world application, no?
This is the opposite situation. The bandwidth between system memory and the CPU is a very limiting factor for CPU performance..the most limiting factor, in fact. Any less than the CPU's FSB / width is significant lost performance. Of cource, most people never push the CPU anyway.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
The problem is architecture, CPU and file size play a MUCH greater role in video encoding than dual channel memory. Which is why, aside from folks who like to benchmark, there currently is no real world advantage.
Ichinisan
28,298
1,235
If you have any significant amount of video to encode, and you can cut the speed of an encoding job nearly in half, I think it's significant (no matter which CPU you're using).
Status
