Originally posted by: magomago
18-55 is most likely the kit lens he is referring to.
Originally posted by: Zenmervolt
In absolute and total honesty, there should not be much difference. From what I've seen of that level of telephoto zooms, performance differences are largely academic and depend more on the individual copy of the lens than anything else. The Sigma 70-300 APO, the Tamron 70-300 DiLD, or the Pentax lens should all be roughly the same in practice unless you get a horrible copy of one.
The 55-300 would eliminate the gap from 55mm to 70mm that you would have otherwise, which might be enough reason to go with it.
ZV
ZV
I had a tamron 70-300 for a while after I bought my own Canon Rebel XT a few years back; it worked OK, but the CA in a lot of the resulting images was terrible. Purple all over the place. Something like that would be my biggest concern.
Nathan
ZV
Nathan
Was it the Di LD version or the older plain Di version? I have the newer LD version and don't have issues with CA, though the non-LD version was rather known for it. The updated version is supposed to be on-par with the Sigma 70-300 APO; I certainly haven't been upset with mine, though I wish it were f/2.8.
Not the greatest examples, but no horrible CA.
ZV
