Question for math/stats guys
BlancoNino
5,695
A person going to a party was asked to bring 5 different bags of chips. Going to the store, she finds 20 varieties.
How many different selections can she make?
Yes, this is a homework question. I don't care about the answer I just want to know HOW to compute it. You can even reword it and use different numbers if you don't believe me :)
Thanks
Edit: Thanks Klin.
KLin
30,429
746
Do we have to guess what the question is in addition to doing your homework for you?
2Xtreme21
7,044
Isn't this just a combination? nCr?
n = total
r = part
20 C 5 ? (It's been a while).
TecHNooB
7,458
20!/5! is my guess. I totally don't remember how to solve these T_T
edit: nm, can't be right :eek:
QED
3,428
Thanks
Edit: Thanks Klin.
Well, let's instead say she needs to select 3 different bags of chips from a selection of 10 varieties. This is a very simple combinatorics problem.
Her first selection can be from any of the 10 varieties. Her second selection can be from any of the remaining 9, and her third selection can be from any of the remaining 8. This gives a total of 10 * 9 * 8 different possibilities.
However, this is assuming that the order the chips are selected matters. That likely is not the case here, so we have to factor out all the ways that she could choose the 3 bags of chips, but in different orders. Call the 3 chips she chose A, B, C. Now she could have selected A first, second, or third, for 3 possibilities. She could have selected B from the remaining two possibilites, and C would by default have been selected at the lone remaining position. Hence, there are 3 * 2 * 1 = 6 different ways to choose 3 bags of chip with respect to order.
Hence, there are 10 * 9 * 8 / 6 = 120 different ways to choose 3 different chips from 10 varieties without respect to order.
QED
3,428
You're very close... you're missing a (20-5)! in the denominator, though.
BlancoNino
5,695
Thanks
Edit: Thanks Klin.
This is exactly what I needed to know. Thanks a ton! The book's example wasn't nearly this good.
KLin
30,429
746
Excel says 15504 different combinations. I think it uses a standard formulation to come up with that number. Look it up on Google.
PlasmaBomb
11,636
I concur.
QED
3,428
Originally posted by: herm0016
that would be one of the outcomes.
Was that a reply to this:
Originally posted by: Schfifty Five
Can the person choose the same bag of chips for all 5 selections?
If so, that's not true. The answer I posed assumes all 5 chips selected are different.
The answer becomes a bit more complex if you allow duplicates in your selections.
herm0016
8,516
1,128
wait.. yea, you are right. 20C5 does not include choosing anything twice. < brain fart
KLin
30,429
746
Read the OP again to see if the 5 bags of chips need to be different varieties. Kthxbye.
