Question For Linuxator regarding hdds in R50e
i remember reading that you got a new hard drive in your r50e and put linux on it. i am considering buying a new hdd, most likely a 5200rpm with 16mb cache and it's 40gb. the question i have that seems no one on any forums i go to know is about ATA 5 and ATA 6. do you know the difference? is there a difference? what kind of hdd did you put in yours? was it easy?
thanks.
A direct question to another member should be asked through PM IMHO. It just keeps the spam and clutter down. To answer your question:
ATA-5 Ultra-ATA/66, 66MBytes/sec, 16 bit data width 40 pin data connector/80 pin cable, with the additional 40 new pins being Ground. The new cable allows ATA/66 to run at a faster rate then ATA/33. Using PIO Modes 0, 1, 2, 3, or 4 and Multiword DMA modes 1 and 2 and Ultra DMA modes 0, 1, 2, 3 and 4. Runs with 60nS Strobes (rising edge to rising edge), but uses both edges of the Strobe producing an effective 30nS Strobe rate. 66MBps Transfer speed = [(1/60nS) x 2 bytes x 2]. Where 60nS cycle time is 2 clock periods at 30nS each.
ATA-6 Ultra-ATA/100, 100MBytes/sec,16 bit data width 40 pin data connector/80 pin cable, with the additional 40 new pins being Ground. Using PIO Modes 0, 1, 2, 3, or 4 and Multiword DMA modes 1 and 2 and Ultra DMA modes 0, 1, 2, 3, 4 and 5. 100MBps Transfer speed = [(1/40nS) x 2 bytes x 2]. Where 40nS cycle time is 2 clock periods at 20nS each.
ATA-7 Ultra-ATA/133, 133MBytes/sec,16 bit data width 40 pin data connector/80 pin cable, with the additional 40 new pins being Ground. Using PIO Modes 0, 1, 2, 3, or 4 and Multiword DMA modes 0, 1 and 2 and Ultra DMA modes 0, 1, 2, 3, 4, 5 and 6. 133MBps Transfer speed = [(1/30nS) x 2 bytes x 2]. Where 30nS cycle time is 2 clock periods at 15nS each. With the introduction of Serial ATA, this is the last expected update of the IDE [PATA] bus.
Also, keep in mind these are theoretical differences. The real world difference between ATA-6 and ATA-7 is negligible most of the time. As far as how hard it is to swap the drive goes: That depends on your notebook. Most recent notebooks take less then 5 minutes to pop a drive in and out. I would do a google search for the service manual for your model of notebook. This will usually have instructions for repplacing your hard disk.
If you can wait a few weeks, I'll have a full roundup of 2.5" IDE drives up. Including 5400RPM 16MB cache, 7200RPM, 4200RPM, everything.
And on your R50e, the drive I think is located on the right side, below the front palm rest. Remove the single screw on the bottom, open the screen, and pull the drive cradle out. There are four screws you need to remove to get the drive out of the cradle; installation is the reverse of removal.
alright, that's cool. thanks.
