Mayfriday0529
Do you really need to have a phone line connected to the Tivo box that DirecTV provides you?
Originally posted by: Jnetty99
Alright sounds good.
One more question
Is there any type of special installation required to switch my regular satellite box to a Tivo box?
I guess only if i want a Tivo box with options to watch one show and record another.
One more question
No special installation unless you want dual tuners and don't already have the lines put in for that. Sounds like you want dual tuners so the question is whether you already have two wires from separate LNBs coming into the room where you want a tivo.
You need to have the phone line on to activate service updates, one of which is coming quite soon which will implement folders and faster menus. If you don't have the phone line attached I don't believe it will ever activate the new version, even though it will have downloaded it.
Yes I want dual tuner option but I?m not sure what type of upgrade would be needed.
I have one dish with a three LNB setup and I have three satellite boxes in three separate rooms. ( This was upgraded last year when i added another satellite box by DirecTV)
Originally posted by: new2AMD
You may get nag screens telling you to hook up the phone but they can be turned off. Are you talking about a stand alone tivo with a D* rcvr? Or a dtivo dvr? Dtivo dvrs are the way to go with the dual tuners.
tivocommunity.com
Originally posted by: Queasy
Just make sure they do a good job and discuss with them where you want your cable run. I had tweedle-dee and tweedle-dum try to run the cable on the frontside of my siding. I made them tuck it behind the bottom of the siding.
