Got a CM Stacker for this new system I'm building, but I am a little perplexed about something very simple. The included 5.25 drive brackets don't fit right on my drives.
I looked at the brackets on the coolermaster website on some technical file, and also some review sites and the brackets they show look different than mine. My brackets have 4 holes and also have 2 pegs in them. So I thought you would put the pegs in two holes on the drive and then use screws for the other two. However, when you do this the drive doesn't line up right in the tower and leaves too much space between itself and one of the black front panel covers. Hope I explained that right.
Anyway has anyone else experienced this, or did I receive some jacked up brackets with my case?
Sorry for the long post.
Thanks to anyone that helps
Mike
Mike
