Anyone here know a lot about cell phone technologies?  Good, because I have some questions.
First, does your cell phone and the communications tower, transmit the signal equally in all directions? Or does the phone have some way of radially directing the signal at the communications tower (or to the phone, from the communications tower)?
Also, with phones that can handle multiple frequencies of the same communications sort (such as CDMA 1900, 800, or GSM 900/1800/1900), do the phones have a seperate communications device for communicating at each frequency? Or does it merely require a software switch to go from GSM 1900 to 900. Also, does it cost a whole lot more for the companies to manufacture a multi-frequency phone versus a single frequency phone (this does not include phones that have seperate technologies, like CDMA and AMPS)? The reason I ask is that there's not a huge price difference between multi-frequency and single-frequency GSM phones. But if adding extra bands is cheap, you would expect all GSM phones to be multiband (even if people aren't going to use the feature, its an appealing thing to have the brochure), but you quickly find that most of them sold in the U.S. are single band.
<-- Uses Nokia 5190 with Voicestream
Thanks.
Thanks.
