Originally posted by: Amused
You want to get big? You have to eat big. Monitor your calorie intake and don't worry about gaining a little fat while bulking up.
You have to cycle your diet into 4-6 month intervals of alternately bulking and cutting. Bulking and cutting is ALL diet. Your workout never changes.
To gain mass, less is more. An overworked muscle will not grow. Work each body part once a week in a split something like this:
Mon: Chest shoulders and tris
Wed: Back and bis
Fri: Legs and calves
Do minimal sets (2-3 for each exercise, no more than 16-18 sets total per workout) and low reps (6-10). Do every set with maximum intensity and to complete muscle failure with perfect form. Stick to the basic compound lifts. Flat, incline, decline and military presses, weighted dips, squats, leg presses, deadlifts, high and low and vertical rows, weighted pull ups, pull downs, seated and standing calf raises.
Skip doing pushups unless you want muscle endurance rather than size. Do your abs twice a week at most. Great abs are made through diet and cutting, NOT from ab exercises. All ab exercises do is help you with stability in your other exercises. They will not make your abs look impressive. That comes with minimal body fat.
If you want to get big, work your legs. Doing so releases gobs more testosterone than simple working the upper body alone and helps your whole body get bigger.
Do small muscles after big. Do your chest and shoulder work BEFORE your tricep work. And you don't need any more than 3-4 sets of triceps work and 3-4 sets of biceps work a week. MOST of your arm size will come from building your chest, shoulders and back. In fact, most see little difference if they include direct arm work or not.
In some people, doing too much cardio can severely limit their muscle growth and even cause muscles to be eaten by the body for fuel. Play with how much cardio you do, and how many calories you take in to find your set point.
Finally, ignore the scale. Go by inches and strength gains, not pounds on the scale. Following the scale is the surest way to burning muscle instead of fat.
