Yes it does... the larger core provides more area to dissipate heat through, and no extra heat is generated with a Barton than an equally clocked T-Bred B.
my 2500+ at 2600+ runs between 46 and 49 depending on the weather that day. today it's 49. the stock heatsink isn't too bad like pspada said. stick a delta on there if you so dare and get 3000+ easily
