QUESTION: Do I Need A Fan For RAM?
996GT2
5,212
Lol no, you don't even need a heatspreader (those are purely cosmetic).
Gillbot
28,830
17
Heat is the #1 killer of electronics so keeping ANYTHING cooler can't hurt. Is it needed? That's debatable.
FishAk
987
It's debatable as in it's debatable whether water is actually wet or it just feels wet.
Those modules are rated for 2133 @ 1.5v, and they have big heat spreaders. If they get hot, it's because something else is heating up the box too much, and the heat spreaders are sucking heat into the sticks instead of away. Putting a fan on the modules won't help heat exit the box.
Gillbot
28,830
17
Actually, if the heat spreaders are hot they are doing their job wicking heat away from the chips but this too is debatable as we don't know the specifics on the OP's system.
ErickMaga
29
I have ram without heat spreaders, and they dont get hot. Not even warm to touch, the airflow of the case it self cools them down.
Gillbot
28,830
17
So do I, want a cookie? I'm also running DDR3-1333 CL9 @ JDEC specs and not overclocking them. Some of these "high performance" ram sticks are merely lower end modules with SPD profiles that force them to run at tighter timings, higher speeds with more voltage. Once you start running things harder than they were originally designed for, they WILL generate more heat.
Billb2
3,035
70
86
No heat spreaders and a fan, but only if you're looking for massive overclocks, otherwise, just run then like they came.
In my humble opinion heat spreaders are a joke.
FishAk
987
Harder than 2133 @ 1.5v?
Why?
My imagination's not as good as it used to be, but I cant think of even a corner case where a fan on those modules would be more helpful than a real solution to overheating RAM- i.e. removing excess heat from the case.
The only way for those modules to get hot is for the heat spreaders to wick heat to, instead of away from them, and that won't be helped by blowing more hot air onto them.
