I have the Wavemaster but i can't really comment on the Lian Li case but I have owned multiple aluminum cases over the years and the Wavemaster is by far the best and quietest of the bunch. The high quality of the case equals no rattling at all and its just a all around quiet and quality case.
the wavemaster is a very low dba case. it is much quieter than my coolermaster atc201. it is still audible, but very unoticable. acutally the loudest feature of the case, is probably the cpu cooler.
