does anyone know if smc makes a pci adapter for wireless pcmcia cards. if not, then is it possible to use a pci adapter from another manufacturer and would it work the same as an smc?
If you want to use the PCMCIA for Desktop you much better off using USB.
You can find a USB card that will cost as much as PCI adapter (may be $10 to$20 more).
Why USB?
PCI Wireless Client Card ends up been stuck behind the computer's case, resultant in obstructed transmission and poor performance. USB is connected to the Port with 2-3' cable allowing the Antenna to be placed above the System for better Transmission.
