Question about Web Design
Rkonster
When you go to a web site, it directs you to index.html or index.htm right? Is that always the case? I am not to familiar with how web sites work and would appreciate any help. Thanks.
EDIT:
Thanks for the replies guys. I am trying to get this information using HTTP::Request in Perl, and I cannot seem to do it. Is this possible? Anyone have any ideas?
I've been told that index, default and home all work, but as a rule of thumb, you should use index.html because it's the one that everyone supports.
Everyone else pretty much covered it, all depends on the server config.
If you want (on a unix host) you use htaccess to set your defaultindex
and index.php index.php3 and any other file extension + default.htm/html/asp etc etc.
What was said about it dependant on how the server was setup is true though, i would imagine all webservers allow you to change it to suit you but generally the defaults have already been supplied...
Let's say I wanted to edit .htaccess to make jackass.html the default index what's the code for that?
DirectoryIndex jackass.html *I think*
Yep, DirectoryIndex filename.ext will do it. Put the .htaccess in your document root (make sure it has the dot, it is a hidden file in unix)
I'm not sure which informaton you are talking about? Are you looking for specific info on http::request?
For example, if I give it a web site, I would like to know what file it directs to.
