Question about using a soundcard with onboard sound.
KhoiFather
Will there be a conflict between these two? I have an MSI K7N2-Delta-L and I want to use my TBSC. I don't think there's a way to disable onboard sound in the BIOS. Can I just install the card and driver and expect it to work fine without anything conflicting?
Yes there's a way to disable the sound in the bios,if there isnt then it's a jumper on the motherboard.
It should be inside your manual,have a quick look.
you beat me to the answer 😛
