Question about thermal tape/compound.
Sigma1914
What's the best way to clean the core when re-attaching/re-applying the HSF with thermal compound? I've heard that rubbing alcohol works, is this correct?
Any help would be greatly appreciated.
BCool
256
Correct, rubbing alcohol works. I've also read that fingernail polish remover works good, haven't tried it though.
