Question about thermal grease.
MageXX9
442
My motherboard died and I'm going to put the old CPU/HS/Fan on a new one, but it seems like I've read somewhere that once you install your retail hs/fan onto the chip the thermal pad is no longer good if you take the hs/fan off.
My question is, what the best way to take off the thermal pad on the chip and HS? Razor blade, alcohol & q-tips?
I have some cheapo thermal paste from Radio Shack that I'll put on afterwards.
andy04
1,000
anything is good. try alcohol 1st, razor blade might leave scratches that may lessen the contact area. I always use alcohol but its very important that you completely get rid of the entire stuff.
I would suggest that you use some good compound like arctic silver. its known to reduce the temp by upto 5 degrees.
Paperdoc
2,523
388
Go to the Artic Silver website. They have good write-ups on how to remove / clean off old thermal pastes and how to apply new properly. Of course, they recommend you apply theirs 'cause it's really good.
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
I think the best thing, if it is well stuck, is the edge of a credit card. Stiff enough to scrape it off, but too soft to harm the metal. Once you have it down to a smear use Isopropyl to clean and polish the surface. If you're going with a material like AS5 put a single rice grain sized dab in the exact middle of the CPU's IHS, and then clamp the HSF down on top of it. Works like a charm.
