- Mar 25, 2001
- 5,287
- 6
- 81
The latent heat of vaporization of water at 1atmospere is calculated to be 2260.44J/g
So it takes 540J of energy to break the strong bonds of hydrogen atoms and convert the water into a steam. This is at the regular 100 degrees of C.
Now lets assume that we are in the Himalayas. The atm pressure at the altitude of 8000M is only about .3 of the atm pressure at the sea level.
The boiling point of water at 8000m moves down from 100 degrees C to 75.5C
Question - will the lower pressure also affect the latent heat of vaporization constant?
I sound to me that it should be lower as the pressure decreases. Because of the lower pressure, less force is required to break the compressed bonds of the hydrogen atoms.
Please elaborate.
Edit: I also have additional question.
How much energy is required to distill the 1 liter of salt water into fresh water at 8000m?
Assuming the boiling point of water is 75.5C
Also,
I would assume that at least some fraction of the energy that was used to boil the water, comes back into the system as the water vapor cools down and releases that extra energy.
Please elaborate.
Also,
