- Jul 12, 2000
- 12,444
- 2
- 81
I am running a 2.4c on an Abit IS-7 (latest BIOS) and am having instability issues. The guy I bought it from in FS/FT guarenteed it stable at 3.1 GHz. I cannot even post the chip at that speed, however I've been tinkering with 3.0, 2.95, and 2.9 and still haven't gotten the setup reasonably stable.
I've eliminated the RAM as an issue as it is PC3500 DDR and I can run stable at 2.6 GHz 1/1 ratio with the ram at 433, however not at 3.0 GHz 4/5 ratio with the ram at DDR 400. I've tried moving the PCI dividers to put them under spec to ensure that was not the cause, however that yielded no better results.
My temps at 2.9GHz under full load are about 56 degrees C and around 44 idle. How does this compare to other chips? This is running at 1.55v (however Winbond reports this is actull around 1.50 under load). Should I attempt to increase the core voltage since Winbond is under reporting to gain stability? From what I've seen these temps really aren't THAT high for this overclock. What is the voltage ceiling for safety on these chips? Would 1.575 or 1.60 still be safe? Any help is appreciated, thanks!
