Question, about slightly weird behavior of a NewQ Platinum equalizer - correction: nForce2 sound!
Jeff7
41,596
20
I've got one of these. It has a display on it that shows sound being processed. I just noticed something strange - when my DVD drive (Liteon LTD-166S) is spinning up, yes, it's kind of noisy. But the NewQ equalizer shows some high frequency sound being processed. I do not have a microphone attached to the system. How is the equalizer picking up this sound?
Edit: Even weirder stuff now - I got a pair of pretty good headphones now, that are really sensitive - they don't require as high input power as previous headphones I've tried. But I can now HEAR clicks when the keys are pressed on the keyboard, and even when the mouse moves! It's not actually the sound of the mouse on the desk either - it's the mouse tracking motion. I turned it upside down, and when I pass my hand close enough to the sensors to move the cursor, but not actually touching it, it sounds just the same in the headphones as when I move it across the desk. Scrolling the wheel gives a sort of squeaky sound. It's like I can hear every bit of input that the computer gives. This is weird.
I can also hear it in the headphones when the hard drive or DVD drive seeks.
Edit #2: It seems to be the nForce2's audio processor that is doing this, as I can record it with sndrec32. 70KB MP3 of the sound. Hopefully it's not too loud; wasn't when I tested it. I set it to record the Stereo Mix at full volume - I hit record, switched to Internet Explorer, used the scroll wheel to move up and down the page, switched back to Sound Recorder, and stopped the recording. (Then I saved it as a WAV and converted it to MP3 with CDex.)
That squeak you hear is what the nForce2 apparently produced, without the aid of a microphone anywhere in the system.
SpeedFreak03
1,094
I had the same problem. If you turn up your CD Audio volume in volume control, you can hear it more. I muted CD Audio, and the problem went away. When I go to play an audio cd in windows media player 9, it plays fine, even with CD Audio muted in volume control.
Jeff7
41,596
20
Weird; I turned the volume all the way up - still couldn't actually hear it through the speakers; it just shows up on the display. Maybe the motor spinning up introduces electronic noise into the audio circuitry, or something like that? Can't really think of why it would do that. Of course, I don't know the detailed technical specifications or workings of either device.
