Question about serial port header
PottedMeat
12,363
475
i see a port COMA on the bottom and the cable is 10" so it seems it's long enough to reach most of the expansion slots.
mine had COM1 opposite the lower slot and i had to cut up an old ide cable to make it to an empty slot
MTDEW
4,284
37
Page 6 of the manual for that motherboard lists COM port cable (Part No. 12CF1-1CM001-3*R) as an optional accessory.
GA-Z87X-UD3H manual pdf
Gigabyte Accessory page
Not 100% sure all pin-outs are the same (universal) for all mobos, so it may be worth double checking just to be sure.
(You can click on Pin Definition in that Gigabyte Accessory link to see the pin-out.)
If they are universal, then the one PottedMeat linked is probably the best price you'll get.
SparkyJJO
13,357
7
Just be aware some of those headers use crappy serial chipsets that really don't work well. I ended up having to get an FTDI USB to serial adapter for someone because the onboard serial was garbage.
John Connor
22,757
618
121
Wow! Thanks for the responses. I never thought that the pin outs could be different. I sure hope the onboard works well. The reason I need it is for programming two way radios and running specific software.
MTDEW
4,284
37
They probably are universal.
I just know if it were me, I'd check to be sure.
Because with my luck, I'd be the one to own the only motherboard where they're different and you need to buy their branded cable. :biggrin:
alkemyst
83,769
19
In all honesty, a USB to Serial adapter is going to be the way to go. Serial ports can be finicky esp. no as they are an after thought.
Engineer
701
In the industrial world, USB generally sucks compared to a built in (or PCMCIA, expresscard, etc) serial port. Have had many issues with USB vs built in, even to the point of killing an $800 HMI while sending the program to it several years ago.
Torn Mind
12,046
2,763
As an aside, I must say that those serial header cables have been around a long time. There was a serial and parallel header in the Pentium II machine I still have.
John Connor
22,757
618
121
I don't understand. A Pentium II would most likly have onboard serial and parallel on the back.
