Question about SeaSonic S12 600WATT PSU
Link19
I have a SeaSonic S12 600WATT PSU with one fan. My case is designed for the PSU to go at the top in the back as almost all cases are. Should I place it so the fan is on the bottom or facing the top of the case?
are you going to mod the back, because the screws will only mount on way... If I had a choice, I'd do it with the fan down, so that it's pulling cool air into the PSU...
Point was if he mounted it fan up, screw holes wouldn't line up. I think he figured it out on his own, which is why we haven't seen him back in here.
