I'm getting my trackpad replaced on the rmbp. Is this integrated with anything else in the unit? Basically I'm just curious what else will be replaced since I know lots of the stuff down there is integrated.
On the previous unibody MacBook Pros the trackpad is integrated with the top case and keyboard. I don't know if that's still true of the retina though.
They are all technically separate components. However the keyboard is attached with like 50 of the tiniest screws you've ever seen, and the trackpad was, I believe, glued.
