palebunny
Hello,
I am trying to buy a replacement battery on eBay for my MacBook Pro. My MBP was purchased a few years ago- the 'Discrete' line, which was the model RIGHT BEFORE the unibody Macbooks came out.
Specs are as follows:
Refurbished MacBook Pro 2.6GHz Intel Core 2 Duo
Part Number: FB512LL/A
Accessory Kit
SuperDrive 8x (DVD±R DL/DVD±RW/CD-RW)
Backlit Keyboard (English) / User's Guide
2GB 667MHz DDR2 SDRAM - 2x1GB
200GB Serial ATA Drive @ 7200 rpm
MacBook Pro 17-inch Hi-Resolution LED Widescreen Display
I'm about to purchase on ebay the following battery :
http://cgi.ebay.com/New-battery-Lap...09911?pt=Laptop_Batteries&hash=item5193c1e957
for (A1189, MA458LL/A, MA458, MA458*/A, MA458G/A, MA458J/A)
This IS the proper battery, right?
Thank you,
C
Accessory Kit
Thank you,
C
