question about rebates for products ordered online...
Delphi00
hello,
if I ordered online multiple products which all had MIR for them, how can I send in the original packing slip to each address (if the addresses are different)? All the products would be listed in a single packing slip and no photocopies are allowed...
do they consider the receipt you get thru email good enough? if so i could just print multiple copies of that....
thanks...
Please check our Rebate Tracking Thread. Start by reading the lead post. Then, use <Ctrl + F> to search for key words related to your subject. If you still do not find your answers, post your question, and someone will probably help you.
AnandTech Moderator
Ignore these old farts. If you're refering to Staples.com, call em up at 1-800-staples and ask a CSR for additional packing slips/invoices. Not sure if any other store will do the same.
ok thanks ppl, anyway, the CSR (hehe) said that I could print multiple copies of the confirmation email I received when I made my order.
Staples is good with rebates, youll have no problems with copies, just put a note saying the original was needed for other rebates on the same receipt.
