Question about processor speed and games
CHfan4ever
3,290
Ok let say i have a processor 1.6ghz centrino( equal to a 2.5ghz pentium iv in terms of performances) and i have a game that require as minimum a 1.8ghz.Will the game start or my system wont allow me to try it?
Painman
3,728
29
86
Hard to say. Some games' installers run a system check and abort if you don't meet specs, some don't. Tell us what game it is and maybe someone will know.
EDIT: You might wanna post this in the Software forum instead ;)
CHfan4ever
3,290
No games atm require a 1.8
The highest MINIMUM requirement for a game atm is DOOM 3 and ask fora 1.6ghz( which is the processor speed of the centrino M40 i wanna get )
I just wanna make sure im buying something i will be able at least to play in mimum setting in a few years.
fishmonger12
759
i dont think it checks your system to see whether your processor is 1.6 ghz, then deletes itself if you don't have one.
if you get a pentium m, 512 megs or more of ram, and a decent mobile video card, you should be able to at least play it on low quality 1024x768 or 800x600.
SrGuapo
1,035
I don't think an game game will force you not to be able to play it. It may warn you that your clockspeed is a little low, but just ignore that.
CHfan4ever
3,290
Ok good was wondering.
Cause i tried to day doom 3 on the m40 toshiba( 730 centrino 1.6ghz,6600go,512meg of ram ) and it was running flawless!!!
A good 40-50fps, 1024x768 and high detail!!!!
I am just scare a bit that a game in the future, that will required a little higher min.requirement( doom 3 is a 1.6 ) will not boot,start.Not because this laptop isnt powerful enough, but because maybe some programmers will not consider the centrino as a gaming machine and it will be detected as a 1.6ghz( even if it perform as good as a p4 2.6 )
Im crossing my finger :)
Well, first, i gotta sell my Desktop PC before getting this laptop...ye..
