I've got a Pentium III 700MHz that I hope to get up to 933MHz. I was just wondering if you need to higher rated power supply when you overclock. Right now I'm using a 250 watt, and everything is running fine.
Your 250W should be enough to get you where you want to OC to.
Intel processors generally use alot less power than an amd so assuming that you don't have an insane number of fans and hard drives, your old PS should be fine
