Question about power supplies.
Santai
44
In the PC I have
CDrom
CdRW
Geforce 4 video
Vantec Aeroflow
umm floppy disk drive.
http://www.ncix.com/canada/productdetail.php?tab=2&sku=9159 (motherboard)
I have no plans to overclock right now, but in the future I will be although when I do I will be buying a few new things like fans/case/power supply.
Will my 250W power supply be enough to support all this? Even if not at maximum efficiency will it fry or something?
mechBgon
Oct 31, 1999
30,699
A quality-brand 300W+ unit would be a safer bet. The original K7S5A developed a reputation for wanting a fairly good 300W+ PSU with 180W+ on just the combined 3.3V + 5V output. If you can find a 340W-420W Enlight, that might not cost too much. Antec, Enermax and Sparkle Power are three other brands with respectable reputations.
DanTMWTMP
15,908
19
directron.com
look in their psu section...they have decent prices on awesome psu's.....
antec or enermax = good
antecs are cheaper there, so get those...IMO, i think the antec's are better..the quality of construction (inside) and reliablity (my freakin fan inside my enermax died within a month..wtf) is much better...
EDIT: oh and if ur worried about resellerratings for directron, they're pretty decent, and i've bought my enermax from them....also bought couple other items....i never had a problem w/ them..and they ship out pretty quickly
Santai
44
Hehe, just bought this stuff so I have no cash left over to buy a power supply.
I'm just wondering if anything really :bad: will happen if I hook it up to a 250 :)
I'm hoping to get a good case / power supply soon.
mechBgon
Oct 31, 1999
30,699
Worst-case scenario, if the PSU overloads, it could take out some/all of your hardware when it goes. If it's a top-quality 250W then it might be ok, but you know what they say: an ounce of prevention... yep. :D
Santai
44
Its brand Aopen, is that high end?
If I disconnected some stuff (CDRW, floppy, ) would it be ok then?
mechBgon
Oct 31, 1999
30,699
AOpen isn't too bad. But really, this seems like buying a new engine for your car and using three litres of oil when it calls for five. :confused: What CPU do you have?
Santai
44
I have a p3 550 right now.
I just ordered this stuff, and since I am in debt to friends to pay for it in the first place, I won't be able to buy a new PS soon.
Of course, if I am 100% going to damage my equipment I am not going to try to use the 250, but I'm just wondering if it is the case where I will surely damage everything (even if I unhooked CDRW/ floppy / sound / anything on USB).
BTW, p3 550 runs fine on it with all my stuff installed.
Santai
44
I can call the store up right now and ask them to replace my Vantec Aeroflow with
http://www.ncix.com/canada/productdetail.php?sku=9403 (generic 350 watt atx power supply)
Is this more advisable?
Need a quick response they close in 2 hours :)
Then, I would be using the 1800xp+ stock fan. I heard its really crappy. But, I can replace that at any time right?
Thanks for your input.
mechBgon
Oct 31, 1999
30,699
If it were a choice between a generic 350W and an AOpen 250W, I would probably use the AOpen. But I think the best plan is to wait a month and save up for a quality-brand 300W or 350W unit if possible. It would be very sad if your power supply failed and fried your motherboard or hard drive :(
Santai
44
Ok,
Thanks, btw, what are the chances of it doing that?
How should I prevent against it?
mechBgon
Oct 31, 1999
30,699
I don't really know what the chances are. Here on the Forums, we mostly hear about bad things happening, not about bad things not happening ;) If you underclock your AthlonXP to 100MHz FSB, that will reduce its power draw, and if you only use the drives you need, that will help too. But the best solution is to wait until you have a better power supply, of course. I can tell you're not going to wait, though, so good luck with your new system, and I hope it works out ok for you :)
Regs
16,666
21
My rule of thumb is to stay away from anything called generic. If it does not have a name, stay away, run far far away.
Im using Allied 300 Watt PSU. This is with 2 HDDs, 2 ROM drives, Athlon 1800 oc to 1.65 Ghz, Geforce 4, case fan, and a floppy. Its running steady at 3.312/ 4.95 . To tell you the truth, I really do not know 4.95 is a good thing lol. But Im sure the PSU doesnt allow it to reach above 4.999 which sometimes it runs at, most of the time. My CPU voltage and DIMM volatge hold dead steady.
Now if my Allied PSU, a brand of which I never heard of before, can do all this at a steady voltage. I do not see any problems with a 250 watt for a p3.
tjaisv
Banned
Oct 7, 2002
1,934
Here are the typical power requirements of common PC components:
Athlon T-Bred CPU (40-90w)
P4 3GHz (80-90w)
Motherboard (20-30w)
128MB DDR RAM (30w)
512MB DDR333 RAM (40w)
GeForce 4Ti (30w)
Radeon 9700 (40-50w)
GeForce FX (40-50w)
Hard drive (5-15w)
Floppy drive (5w)
Optical drive, eg CD or DVD (15-20w)
Zip drive (10w)
SCSI hard drive (20-35w)
PCI card (5-7w)
System Fan (3w)
CPU Fan (3w)
USB Device (5w)
IEEE 1394 Firewire (8w)
Mouse (1w)
Keyboard (1w)
Above wattages are based on figures reported here:
THG, ezboard, PCWorld
