Originally posted by: LiQiCE
On some motion sensors you can flick the switch On/off real quick to turn off the motion sensor and turn the light ON permanently. Flicking it on/off real quick again should turn it back to motion sensing. I'm guessing when you turn the "Manual override bypass" on, you're enabling the ability to force the light on by flicking the on/off switch.
