Question about oil pumps
Status
Not open for further replies.
bommy261
1,057
I was chatting with my cousin like 2 weeks ago who is a mechanic on diesel engines. We started talking about cars and shit. We got into a discussion about how startup is the worst time for your engine. Because oil sinks to the bottom of the engine when its off, the engine probably cycles 5-10 times before oil is on all the cylinder walls and pistons. So, why not just have an electric oil pump that turns on when the radio and other electronics go on and starts pumping oil. Would this not prolong the life of the engine?
Anyone care to enlighten me as to why this is not common place in cars?
bruceb
8,874
111
Maybe. But if you put one in, it will go almost forever. Think of all the money they would lose from repair cost.
LTC8K6
28,520
1,576
There's still a good film of oil on the parts, so an electric pump isn't really necessary.
HarryLui
1,518
33
Most of the time, people get tired of their cars faster than the engine dies.
Beside, the number one killer of engine is probably due to lack of regular oil change, not minor engine wear on start up.
exdeath
13,679
10
It's called boundary metals. Lead, moly, zinc, etc, coats the moving parts and lubricates them in the absence of oil pressure. It's also the job of the oil filter to have a properly designed anti drain back valve so that oil flow begins immediately as soon as the pump turns.
Eli
Super Moderator | Elite Member
8
It's just not necessary, though I won't disagree that it wouldn't help.
You have to understand that everything is still coated in oil inside the engine. It doesn't drip off, leaving clean, grease free metal surfaces.
bommy261
1,057
thanks for the info, i thought overtime it would settle to the pan and leave the important cylinders and walls bone dry
Status
