Question about memory timings and speed
Hulk
I realize that most memory modules are rated for a certain speed and timings. For example these are rated 1833MHz at 9-10-9-28, 1.5 Volts.
Is there a way to ascertain at say 1600MHz this memory (or any other) would run at lower speeds, say 1600MHz, other than trial and error testing?
Or is there a "rule of thumb" to approximate such things?
Memory will always run at a slower speed, but not necessarily at a lower voltage rating.
Some higher speed rated DIMMs are also rated at a higher voltage, say 1.65v.
Running these DIMMs at a lower speed doesn't mean they will function properly at a voltage less than what they are rated at.
If you want to run memory at the rated voltage but a lower speed... You're golden.
The memory may have operational information showing what the ratings are, perhaps they mention some lower voltage possibilities when run at slower speeds.
I didn't ask my question correctly. Besides trial and error testing is there any "rule of thumb" on what timings you can run a certain stick if you are running it slower than rated. For example, the stick mentioned above is rates at 1833, timings 9-10-9-28. If run at 1600MHz, how much do you think the timings could be lowered? Do you think it would run CAS 8 instead of 9?
The utility CPUZ (SPD tab) will generally list the JEDEC info including timings, and voltage, for running memory at lower speeds.
Yes look at that SPD info, you can select multiple listings to see the various different settings.
Certainly the best approach would be checking the SPD information.
I also compare kits rated at different speeds and same or different voltages from the same manufacturer. For instance, if one kit of G.SKILL is spec'd at 1600 and 9-9-9-24, and a second kit is rated at 1866 10-10-10-28, you can also compare the voltages, and it would be quite likely that the RAM at 1866 spec will run at precisely the specs of the 1600 RAM.
