Question about memory and overclocking
pap1stik
7
Quick question: Can I overclock the FSB on an ASUS A7A-266 mobo past 133mhz ddr if both my memory sticks are PC-2100? Thanks!
magratton
523
i would highly recommend you repost this over in th CPU and Overclocking forum. A lot of things need to be taken into account if you are going to do this.
1) What CAS latency is your RAM
2) What kind of RAM is it
3) What kind of Power Supply do you have
4) What kind of processor do you have
5) Does your motherboard allow you to define ratios between the FSB and the CPU
