Question about LAN gaming and CD issues.
bluehorizon
564
Here's the situation. 10 or 12 workstations will be connected to a server for network gaming. There will be over 8 games available, each requiring a CD to play. How would all the workstations run a copy of a particular game without the required CD? This is assuming it wouldn't be a problem to purchase a copy of the game for each PC. Would the game have to be installed on each PC? If so, how would they all run it without a CD in the drive? CD hacks aren't an option.
Also, what kind of hardware would need to be in the server to handle something like this?
Necrolezbeast
838
not sure of a network/server option to get the cd access....but you could make and image of the cd's and distrobute to all the workstations and use a program like daemon-tools to mount the image....no need for individual drives on the workstations and the like. Someone else may have the server option idea, but I have no idear
samuraijake
51
Try a program like Virtual CD. It will allow you to copy the CD contents to a hard disk and then map a virtual drive to that directory. If you do this on the server, you will have network access (from you 10-12 networked PCs) to those virtual drives.
That's going to be a lot of traffic while loading the game. Might want to consider gigabit ethernet. Other components in the server = as much as you can afford.
Hoober
4,432
69
Another vote for Virtual CD. I use it at home and it's great not having to swap CDs or even worry about them once the CD image has been created.
gils2000
24
Ok this well work for sure I promise. Not to say all the other suggestions wont it?s just this a monkey could do. Go to www.gamecopyworld.com and they provide a no CD EXE for free. It is for people with you kind of needs. I have used it a number of times and it hasten let me down yet.
Good luck and happy gamming!
