- Apr 5, 2005
- 12,090
- 701
- 126
We ordered a 33 x 21 inch stainless steel sink to replace our POS double basin sink which cant fit any pots.
The problem is, our old sink is 33x22. I measured the length opening and it's 21 inches. Now I know that we can drop the sink in without an issue as it will still fit in the hole, but i'm afraid it might be too heavy if it's only the width part of the structure holding it?
Could I create a one inch long shim/spacer and drill it into the inside of the counter to reduce the length to 20 and have it support the sink, or would this be a bad idea? It's a formica countertop. I think this would solve the problem of spreading out the weight evenly among all sides of the sink.
