Originally posted by: NaOH
ok so I looked at the back of my Denon and where the speakers hook up it says 6ohm and up...is this bad? Also, i can't find a way to set the crossover on my reciever.
BTW I have the Denon AVR 2800
You will be fine as long as you don't really crank the volume. If you hear distortion, turn the volume down.
Since your receiver has preouts, you can buy an external amplifier if you realize you need more power. However, depending on costs, it might be better to get a new receiver if you choose to go that route.
Frankly, I don't think you will have a problem with the power front.
Your receiver should have at least a "speaker = small" setting. On some online reviews, they mentioned that your receiver has highpass and low pass settings from 80/100/120 hz. Just choose the 80hz one if it exists.
