Originally posted by: Evadman
It is written on the dor jamb. the sidewall just lits the maximum the tire can endure before it goes pop. If you are carying more weight then normal (but stillw ithin the vehicles weight rating) then you will need more pressure. If all your car caries is you, then you can likely go less.
This is how you figure it out for your specific car and application. Fill the tire to recomended pressure. Use a piece of chalk to mark the tire in a 2" wide band across the tire tread, then drive around the block. Then check the chalk band. If more chalk is whiped off in the center then the sides, then the tirte is overinflated. if it is wearing more at the edges, then it is under inflated. Change the PSI by 2-4 psi and retest till it is even across the entire band. Then write that PSI somewhere, as that is what you should be inflating to. You will need to do this on the front and rear. If you want to be perfect, then do all 4 tires since the drivers side will likely need more pressure (maybe 1-2 psi) as that is the side that you sit on.
My dodge had a recomended pressure of 55 psi front and 85 rear. I never really caried anything in the back, so it was way less. When I switched to the thornbirds, the pressure I ended up using was probably less then what you will be running. the max pressure for the thornbirds was 45 psi. Putting 85 psi in them would have severly bowed the tread, and likely damaged the tire, if not caused a blowout. The tire place put in 50ish lbs all around(discount tire). After the chalk test, I ended up running 30 psi front, and 25 rear. I had a 5 gal air tank so if I needed to take a load of bricks to a customers house, I could just toss another 20 psi in the rear if I had to.
Having your tires properly inflated gives you the best gas milege, best handling, and longest life. If you screw up, you can end up on your roof.
