Say I have a switch as a LAN backbone, and then each room has a hub for the computers in the room.
If computer A is sending data to computer B in the same room, the hub will send the data to every port that is currently connected, correct? Since one of the ports is connected to the switch, what will the switch do since the data goes to the same port on the switch that it just came from? Will it ignore the data, or will it send it back? If it sends it back, then won't computer B actually be getting 2 coppies of everything computer A sends?
