question about heat
dsj
The nv monitor says that the cpu is 54 degrees. The motherboard monitor says 77 degrees. The bios says 66 degrees. the display on my case says 51 degrees. Which one is correct?
This is a funny one. I would get another thing to verify. Maybe a Thermaltake Hardcano 13 or something which has thermal probes.
If you can't, I would generally trust none of them.
But the computer constantly restarts even during the nv performance tuning when the case displays the temp to be 53 degrees. So I think that the motherboard monitor is correct.
Try this Aida 32 just extract the .zip contents to a folder somewhere and run the .exe (no installation needed). After that you'll get a splash screen loading a bunch of stuff. Once the main window is open click on 'Computer' then 'Sensor' and you should get Mobo, CPU, and AUX temps as well as fan speeds and voltages. Good stuff Aida 32 is!
