I made a thread earlier about the temps on my old Vapor-X 4890. The core temps were fine, but the MemIO temps were very high at idle (75-76C) and dangerous at load (106C). I did contact Sapphire about the issue and they offered to RMA it, but I figured since this is my old card I might as well play around instead.
Figuring the issue was simply poor application of thermal paste, I removed the heat sink and removed the crunchy thermal gunk with 99% isopropyl and a microfiber cloth and applied a nice thin layer of Arctic Silver Ceramique with a razor blade. Re-mounted the heatsink and booted. Core temps dropped about 5C at idle but the MemIO temps had actually gone up, sitting around 90C at idle.
Upon popping the card back out and removing the heatsink, I could see that the base of the heatsink was not making contact with the upper right corner of the GPU. My stopgap solution was to clean off the Ceramique and do a new layer, but this time leaving an extra thick layer to the problem corner.
The core temp is still fine, sitting at around 51C at idle but the MemIO is back to the original 76C. Clearly, it is making better contact with the extra goop, but still not enough to solve my issue.
Suggestions?
Suggestions?
