I've been doing a fair amount of reading, and I'm not sure I've got all of this information straight about the new HD audio formats.
The way I understand things is as follows: a receiver can get audio information that has already been decoded by the player in pcm format through HDMI. Or it can have raw information sent via bitstream to be decoded by the receiver. But no current players can bitstream this audio formats as I understand it, but they can decode it and send it through as pcm.
So, if one were looking for a new receiver to listen to these, do you have to buy one like the Onkyo 605 that has the nice little Dolby TrueHD and DTS-MA logos on it, or will any receiver that supports multi channel pcm through HDMI suffice? My understanding is that if the HDMI revision is high enough to accept the multi-channel pcm, then if you're happy to let the player(s) do the decoding, then you don't need necessarily something like the 605 that has its own onboard decoder. (My question becomes--what difference does it make which one decodes it?) If that's the case, is there a quick and easy way to tell if the receiver can support the new formats through pcm?
So to be specific about things: I have a PS3 for BD and a HD-A2. The PS3 can decode the Dolby, but can only do the "core" of a DTS-MA (for the time being). The HD-A2 can do the same for HD DVD. Am I right about all of this, or am I hopelessly confused?
