I have an encloser I wanted to know after that harddrive is plug in and spinning do I jsut remove the usb and power to take it with me. or what do I do so I wont ruin the harddrive.
Down at the bottom-right, just left of the clock, are all your (hidden) system tray icons. Press (< ) to show them, then click the one for "Safely Remove Hardware."
It will list removable / hot swappable drives including your enclosure. Pick the enclosure, wait for the message saying it's safe.
