Stg-Flame
With the PC I just built, I'm using a Klipsh (links below) 2.1 stereo system that just has a single green 3.5mm jack, but it only seems to work when I plug it into the front headphone port on the PC case. I've tried plugging it into all three different audio jacks on the board and nothing works. Now, this wouldn't normally be an issue, except when we try to load up a game (Witcher 3 for example), we have to unplug the 3.5mm jack and plug it back in before there's any sound. It worked just fine with Fallout 4, but we tested several games and the majority of them don't have any sound until the jack is unplugged and plugged back in.
Please tell me I'm missing something extremely simple here. It seems a little weird that a modern-day motherboard wouldn't have on-board support for 2.1 setups. Also, the specs on the Newegg page says it supports 7.1 channels, but there's only three ports whereas my motherboard has all five, so I'm a little confused here. I should have looked into this prior to purchasing the motherboard, but I just assumed the green jack on the back would allow for 2.1 stereo.
The motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813157759
Stereo: https://www.newegg.com/Product/Product.aspx?Item=9SIAC4Z54X9677
The case: https://www.newegg.com/Product/Product.aspx?Item=N82E16811853012
My motherboard (for reference): https://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
