Question question about fans + AIO for Corsair 4000x case I bought
QueBert
22,890
1,090
It comes with 3 ML120 fans in the front, there's room for 2 120 or 140's in the top and 1 120 in the rear. The CPU will either be a 7600x or 7700x. I'm torn between putting an h100i Elite Capellix in the top and a 120 in the rear. Or taking the 3 fans from the front, and installing an h150i Elite Capellix there and putting 2 140's in the top and a 120 in the rear. I know most recommendations I see say to mount the rad at the top, but I'm wondering here about the 240 vs 360 rad on a CPU that runs as hot as the Ryzen 7000's. This computer will have no graphics card for probably 4 months. I want to wait for the 7000 cards to drop to see which way to go. I'll definitely be going Radeon, and something around the 6800 level.
In2Photos
2,446
2,689
Ryzen 7000 series runs hot, but its been determined that you can keep them from throttling with just about any typical cooler, even $30 air coolers. A 240 on top or a 360 up front will work fine and neither one will affect performance. You might see a couple of degrees difference on 1 vs the other.
QueBert
22,890
1,090
Thanks for replying, a little concerned because Steve from Gamers Nexus really really crapped on the 4000d for its thermal performance. Maybe 2 140's on top, a 120 in the rear and an Noctua NH-U12S instead of an AIO. I'm thinking 2 fans on top instead of a rad should get better air flow going on.
In2Photos
2,446
2,689
If anyone actually replies, what about 2 140's on top, 1 120 in the rear and an NH-U12S instead of the AIO?
I'm doing a build for my daughter with a 7600x in the new Lian Li 216 case. I plan on just using the stock fans, 2 160mm intake and 1 120mm exhaust along with the ID Cooling SE-226. I'm confident it will be more than adequate so that solution should be fine as well.
QueBert
22,890
1,090
Thanks for the video, I keep flip-flopping between an AIO and the Noctua NH-U12s. I watched another long video from JayzTwoCents on the Zen 4 temp thing. It sounds bad but once you do some research it's a non issue. Both coolers would do the job here I was just overthinking it.
Dec 10, 2005
27,480
11,811
Sorry to bump such an old thread, from what I recall of the GN's videos on these cases: there were really two main things: 1) the 4000D non-airflow version, with the solid front panel and only tiny inlets for front intake, is horrible for aiflow; 2) for the airflow variant, they really only test under "stock" conditions, which was just a single 120mm intake and a single 120mm exhaust, and the tests showed it was okay - very middle of the pack.
I've been using the 4000D airflow with the mesh front and it's been fine. I'm not running some super high-end setup, but it's got plenty of airflow, especially with 3x 120mm front intakes and 2x 120mm exhaust (1 rear, 1 top/rear). And with the ample front intake, I've been able to really turn down the fan speeds to have a pretty quiet setup.
