I have a Silverstone LC13B-E case that has 1 optional place/hole for a fan on the side of the case. You can look up the manual on the website (model LC13-E) to see what I am talking about.
There is a piece of metal mesh covering the hole on the outside of the case. The piece of mesh has hooks that are hooked into notches surrounding the hole. I bent the hooks and removed the piece of mesh to install the fan. I hope that was correct.
Anyway, the 4 screw holes for this particular fan hole are very small (much smaller than the usual x-large screws that come with the usual fans. Is there a special fan that I am supposed to buy that has special small screws? I haven't seen anything like this before
One other general question about this case. The bag of screws has 4 really long screws that are only threaded near the tip and 4 similar type screws that are a bit shorter. What are these for?
