Question about fan connector
colt1911
9
My motherboard has a four pin cpu fan plug on it and the Zalman 9700 that I'm considering buying has a three pin . My question is will it work or do I need an adapter? If so could you recommend a place to buy one. Thanks
eelw
9,966
5,109
Not required. The 4th pin is for PWM - pulse width modulation. Fan control on a PC unfortunately is not linear in fashion. Using PWM, it should make SW fan control more linear.
Zepper
18,998
The first three pins of the mobo connector are the same as any other - with the guide tab there you shouldn't be able to connect your fan wrong without forcing...
.bh.
