question about epox 8kha+ and radeon 9700 pro
Kalis
39
Biggest question is will it fit!
hehe
I made the mistake of getting a leadtek gf4 Ti 4600 which wouldnt fit due to some capacitors being in the way of the card seating properly. It now resides in my girlfriends system and Im still using a gf3 ti 500.
Does anyone know if the radeon 9700 pro will work on this board?
Toymaker
192
My Radeon 9700 Pro is just under 7 inches long (6 7/8) not including the mounting bracket (about the same as a Ti 4200). If the capacitors are 7 inches or more from the agp card screw plate (or motherboard edge, whichever you want to measure it from) you're ok. I've read that the Ti 4600 cards are longer but i can't be sure since i've never owned one.
