I have a APC 1300 VA UPS that I only have hooked up to my PC and my monitor. I have been having problems with the UPS as long as I remember. Primarily, my PC shuts off any time the UPS activates the battery.
According the the front panel, I am only using 17% of the capacity of the UPS. My monitor is an 23" Dell LCD and my PC has a 500W Antec EarthWatts PSU. I sent a note to APC and I received the following response:
The Back UPS outputs pure sine wave when it is receiving power from the wall, and it outputs stepped approximation to a sine wave when on battery mode. Stepped approximation to a sine wave is an ideal for most of the modern Computer and Computer related equipment. However, if the connected equipment does not accept stepped approximation to a sine wave, then it will shutdown as soon as the UPS transfers to battery. My research has found that the Antec Earthwatts 500 W power supply requires pure sine wave as well as the transfer time of the UPS should be less 4 ms in order for it to work properly. In this case, the Back UPS will not support the Antec Earthwatts 500 W power supply as it outputs stepped approximation to a sine wave on battery mode and the transfer time of the Back UPS is 4 to 8 ms.
I just ordered a replacement battery for the UPS (since the battery failed the self diagnostics) but if I really need sine wave and a faster transfer time, I need to cancel the order and get a different UPS. It sounds like he is trying to upsell me a new UPS but I'm not sure. My gut tells me that this UPS should be able to handle my system.
Any comments would be greatly appreciated.
Thanks.
Thanks.
